D Doggone Member Oct 14, 2003 #1 Does anyone know the part number of the bracket that is needed for the DIN pocket install?
D Doggone Member Oct 14, 2003 #2 Maybe there isn't any bracket for the Din Pocket. How do you take the pocket out?
1 1sty Member Contributor : 2006 Toyota Tundra DC Oct 14, 2003 #3 There is and I list it in the sticky. Pull the pocker out. Please list your car so i can be certainyou are gettgin the right info.
1 1sty Member Contributor : 2006 Toyota Tundra DC Oct 14, 2003 #4 Ah! Heres the bars mazda part number: Stock MP3 and MSP Support Bar: TA06-66-9B1 Its to support the radio though not the pcoket.
D Doggone Member Oct 14, 2003 #5 Great thanks. I think I found the problem. The pocket door is hitting the top part of the radio gasket. So, it isn't closed properly.
D Doggone Member Oct 14, 2003 #9 No, it is hard plastic. That is the problem. I will have to grind down a bit of it to clear the door.
1 1sty Member Contributor : 2006 Toyota Tundra DC Oct 14, 2003 #10 ??? YOu mean the raidios trim ring? What radio are you using and in which car.
