Difference in front fenders from sedan to PR5?
Neaspeed
2003 Mazda Protege 5
I have looked around junk yards for PR5 and no luck. s*** load of protege sedans though. I was wondering does anyone know if this should fit? I need 2 front fenders for my protege 5.
I believe they would as I've seen lots of protege 5s running MSP bumpers and everything lines up nicely.
Yep, hatch and sedan are the same. I see you have an 03 so you have the wiring for the side markers already in place.
^yeah pre-01 sedans had a different front section because they used 2 piece head light housing...the signals where shaped differently, and a completely separate housing iirc...so get fenders from an 01+ sedan...and a 02.5+ for side markers if you need them, but you can easily drill holes for those using your original fenders as a template if need be...
Thanks, My right fender is rusted, and left side all jacked up from an accident. So need both fenders and a drivers headlight. I will look for 02.5 fenders with
the side markers. Gonna have to hit up the junkyard this weekend.
