Did a little logging with the 1.03 map...wow
I just found it funny that you made the "decision" to return the car back to stock in less than an hour from your original post. And the AP is uninstalled AND sold in just a few hours! I'm sure you made the choice after much deliberation but it's amazing how fast the developments unfolded!
lawl....
if you dont want to sike get a meth i have piasini flash and with stock tmic sri and forge bpv and tespipe i was spiking to 21psi and keeping 18psi now with fmic im spiking 19 and holding 17 because of core size and piping....
I wished you guys would stop pushing the Paisni when the guy selling it can't even be contacted or respond to PM's or Emails.
And NO your boost didn't drop due to core size and pipes. It did because as you add mods to your car the boost will continue to drop because the Flash can't keep up. It works well on a Stock or Simi-stock car but as you add mods that increase the breathing it gets worse and worse.
I mean really guys. It is ONLY common sense. One flash can't possibly work for every stage of modding. That is just stupid talk to believe that you can toss any mods you want at a Paisini Flash and it will make the changes to your ECU accordingly. Like it's some living entity. I don't think so and you're a tool if you actually believe that.
I mean really, if that was the case then your Flash should see the bigger core and longer pipes and adjust (smash)
To the OP. I would like to know which MAP you were using. To me it looks like you were using the wrong one for your mods. I simply can't see any map with afr's that high. 13.6 would make me uninstall the map faster than you did.
