mazdaspeed32007
- Mazdaspeed3
are denso spark plugs from pg 1 step colder as the ngk's?
not sure which all plugs PG have listed on their site, but he denso's you want are the ITV22's. they are one step closer than stock and are way closer to the proper gap than the NGKs.
Wow! The OP asks for help, someone steps up and volunteers to help with the exact info asked for, with the right Denso plug number for one step colder, even tells him that they are gapped correctly (we have to regap the NGK's I prefer) and the OP slams him?
What more can the OP want? Frustration over the situation is understandable. Lashing out at someone trying to help? Let no good deed go unpunished.
i did slam him at all. i was just saying the phrase...."your telling me" like...yea i know...they aren't even close. sorry if it came out that negative. no harm meant.
But I can understand that you might not want to do the gapping yourself. It is delicate and does require patience.
lol?
Sort of tongue in cheek. But, for those not familiar with the wire gauge tool and how to carefully bend the ground electrode, the center electrode can be easily damaged. For those with just a little bit of experience -- a piece of cake.
Hate to see someone throw away a good set of plugs that could have been re-gapped to proper specs.
Now it makes sense -- I guess I was a bit dense on your situation. If you got 45K miles on that set, then it was time to get them out of there.
I don't think there's a dime's worth of difference in performance between the Denso Iridium and the NGK Iridium IX in the same heat range. It's just that the NGK's in Range 7 do have to be regapped as they come at .045 or so - huge gap.
A gap of .030 works best for me with my mods and on stock tune.
For those with dyno dollars and time, you can adjust up as much as .008 or down as much as .008 (.002 at a time) outside the factory specified gap range and find the sweet spot, which could be worth as much as 5 whp, and this will vary from engine to engine, even with the same mods, for some reason.
With turbo engines, increase in boost over stock levels (custom map ??) will usually produce more power by narrowing the gap.
