I think the length actually may be a problem. I checked the coil packs and that spring is only half way through the pack. Therefore if the plug isnt far enough up there its not going to make good contact. A lot of SRT-4 guys have mentioned this as an issue with using the Denso's without modifications (ITV22's). When i first put them in my A/F was all over the place. I checked ALL my hoses and nothing was even remotely loose. I have upgraded stainless clamps constant torque clamps all around too. I took the plugs out and checked them and the gaps were good. When i put them back in i screwed them in about 5/6 of the way so the coilpacks would be more on the ends of them. Voila and the A/F is quite a bit better but still off. I'm going to swap the stockers back in and check the A/F and if it levels out like it was before the Densos, they are coming out.
