Finally had a chance to check in here. Wow, a lot going on. Hey Peepsalot, should have e-mailed me direct, I check that at least once a week or so.
From what I can gather from the earlier posts, his problem could very well have resulted from not moving the bar stop as suggested in the instructions. This will cause odd angularity to the strut. If a bolt is loose, especially in this useage, it will have a greater likelyhood of failing.
You know, to be honest, I had a difficult time deciding to offer the end links to the public. Not that they do not improve the handling, they have to be set correctly, they will make noise and have to have the rod ends replaced periodically. But......they do stiffen up things quite a bit. MAM's suggestion for the high angle capable rod ends is right on. Only they are about $50.00 or more each. If it is set up right, I can not see having a problem under normal use. The rod ends can be purchased through "JEG's". If you want the kit only to get rid of the Klunk, then you will do fine just with the kit and pass on the end links. Stocks work fine. My original design intent was to make brackets for a larger rear bar. They work very well to simply get rid of the Klunk.
Some cars I see, the lateral arm comes way close to the grease fitting if used with the energy suspension greasable bushings. I would unthread the fitting and use when greasing.
As far as having the end arms level, this should be done. In the neutral state if the bar is level, then when it is called upon during transiant maneuvers, it will be in the optimum position and move through an acceptable arc.
Well, I am finally at a point where I am contemplating doing another run of the brackets. Spoke to my welders today. What would you guys like to see different? Let me know in the post.
Like I said before, pricing will be $269.00 without bushings.
Godspeed!
Dave
www.delsingmotorsport.com
