DEFI-D guage mount??
Hey Tito, if you get the Defi Gauges, maybe we can figure out installing them together. Mine are still un-installed right now, but I got mine from Sam, top notch. I am going with the Autometer Pillar.
Jared. If you need to know where to run all the stuff hit me up on the IM ill take some pics and show you where to run it all.
JDM Sam said:
i recommend getting a pillar pod to hide the wires as this will look cleaner hiding the wires.
I have a pillar pod now. We drilled some holes in it and ground down some parts inside the stock A-pillar plastic and mounted the pod to it.
All the wires and the vacuum tube run up behind the plastic.
We wired the the lighting into the dimmer switch too.
The FM boost gauge I have is white with a red light, only it doesn't look like the stock lighting.
Chris, Sam hooked me up with the 3-Pillar pod for a very decent price. It was painted Grey to match the interior by Pirana (Victor), and I installed it on the pillar. Everyone says it looks stock. Here is a picture:
