Dealer based brake flush question (Help! Those who know dealer services)
bmninada
Contributor
2016 CX-5 AWD GT+iActive Soul Red
I replaced my 10+ year Mazda OEM hoses with Goodridge stainless steel braided lines. Then did a manual bleed. Unfortunately, result is not good.
After much debate I realize in most probability I introduced air while changing hoses. I can bleed again but my fear is - what if it's in the ABS? 1 solution I heard was to take the car out - brake hard and fast 6 to 10 times and usually works (for ABS). The keyword here is "usually".
I have decided to bite the bullet and go to the dealership. I know Mazda does offer a software option to cycle ABS for bleeding. I believe Mazda calls it DSC. Problem is this: When I talking to service guy and this exact thing I got back from 6 dealers I called: "We put the car in service/maintenance mode and flush. It takes care of ABS bleed. There is only this single process, as per Mazda and that's what we do." Another funny thing is they won't budge - since car originally took DOT 3 they just won't put DOT 4. This one though - I understand and accept.
My belief has always been car in service/maintenance mode = EPB disengaging. I thought that option to bleed "DSC" (as per Mazda) is hidden elsewhere in the menu. I may be wrong since vaguely remember reading it somewhere.
I need some assist here : when dealers do a brake flush on a 2016 CX5 does the Mazda approved process automatically ensure ABS bleeding takes place / ABS cycles thru while flushing?
Can someone assist me? Note: If I had not changed brake lines I wouldn't be asking this. In normal situations - the usual brake flush process is perfectly fine. Only asking since I flipped the hoses, etc.
