You can check the part# and manufacture date sticker on the back side of both LED headlight housings and see what are they. If you have the latest version which is the "J" version, you should be fine although the sticker would still say "H" version. The revision is the last character of part # in alphabetic order (none->C->D->G->H->J) as there must be something wrong in any of the previous versions hence Mazda has to modified it again and again.Bought my 2016 CX-5 GT in December and driver side DRL is flickering. Dealership is replacing under CPO warranty. Currently at 44k miles. Curious if the passenger side was ever replaced or if it will go on me once the CPO warranty expires.
Wife just got back and its raining. Here are the info of my replacement LED headlights:
Passenger's side (installed 3/17/2018):
HL Sticker states: KA0G-51-030H (Manufacture date 12/28/2017)
Invoice states: KA0G-51-031J Unit (R), Head Lamp
Driver's side (installed 3/17/2018):
HL Sticker states: KA0G-51-040H (Manufacture date 12/13/2017)
Invoice states: KA0G-51-041J Unit (L), Head Lamp
So your H version LED headlight seems to be the same as my J version after all.
Pls, what version was the damaged headlight? Thanks!
No, later H/J version LED headlight on 2016 CX-5 looks different from older C version. You can clearly see it's dot-matrix style on accent strip LED DRLs for newer H/J version but it's fibe-optic style on C version. The color temperature is different between the two, and the light output is weaker on H/J version LED DRLs.Perfectly. Why are you going to buy a headlight ?.I now have a KA1F-51-040C. I can buy a KA1F-51-041J (H). Should this fit together?
Europe has better E-code headlight and your LED headlights are different than our US DOT version. Your LED headlights have different part numbers but the revisions seem to be similar.The DLR on the left side is dimming. No warranty anymore, and Mazda will not compensate the expenses for a new headlights because I've bought the car in another country (I live in the NEtherlands, my car is from Belgium). A new headlight via dealer is far too expensive (> 1000 USD). I can get a used one from a damaged car for about 100 USD. My dealer will assemble it for me.
I read parts of this thread, and the DLR problems should be solved in the 041J version. Is this right?
After many revisions (none->C->D->G->H->J) based on the history of US part numbers, looks like Mazda has settled for J version and so far so good.
The E-code headlights (European specification) have better light pattern and cut-off than that the North American headlights regulated by DOT. That's why you see different part numbers between your E-code LED headlights and US LED headlights.What do you mean with E-code?
So I can better choose for a C or D revision? Or replace both headlights with a J-version?
Do you know how tot disable Them?
For the record, here is an official copy of instruction to disable the DRL function for 2017 and older CX-5s obtained by bigtex from his Mazda dealer:
Is this the file:
But if your country requires DRLs such as Canada Mazda may have disabled this procedure to disable the DRLs. You can always pull the DRL fuse though.
Just checked...Drivers side is KA0G 51 040C and passenger side is KA0G 51 030C. Both have manufacture dates of 09/2015. So I guess they are both original to the car. Hopefully I can catch the passenger side before it goes!!!
Just be aware that the actual part numbers are different from the numbers on the stickers affixed to the LED headlights.Just got my drivers side headlight replaced with KA0G 51 041J. Just FYI to those keeping track. Cheers.
Yeah if the cost of replacement on these LED DRLs is similar to incandescent or halogen bulbs, nobody would complain! But now you're talking about $1,250 list for a single replacement unit of LED headlight for flickering DRLs! With labor Mazda dealer often charges $1,500 for a single LED headlight replacement on something which is supposed to last a lot longer than 2 years!
The only good news out of this is the list prices on latest "J" version of these LED headlights are cheaper now:
UNIT(R) HEAD LAMP - MAZDA CX-5 Right with LED
KA0G-51-031J (Replaces: KA0G-51-031C, KA0G-51-031D, KA0G-51-031G, KA0G-51-031H, KA0G-51-031)
List Price: $1,059.36
UNIT(L) HEAD LAMP - MAZDA CX-5 Left with LED
KA0G-51-041J (Replaces: KA0G-51-041C, KA0G-51-041D, KA0G-51-041G, KA0G-51-041H, KA0G-51-041)
List Price: $1,048.88
Hopefully the problems on LED headlights have been truely fixed after that many revisions during these 2 years ⋯ (nailbyt)
Got my 2016 CX-5 back with a new pair of J version LED headlights replaced under warranty due to failed accent LED DRLs. Mazda/Stanley actually has changed the hardware design of the accent LED DRLs as my originals use fiber optic LED accent light similar to BMWs angel eyes, but my new ones now have many bright white LED dots which looks like most other LED accent DRLs. Of course I like smooth and more expensive fiber optic LED accent DRLs much better, but apparently Mazda/Stanley couldnt overcome the reliability issue with fiber optic LED accent light for some reason and had to change the hardware design totally. Now I know why the MSRPs on newer J version LED headlights are about $150 lower than previous versions.
View attachment 218817View attachment 218818
No the part numbers on invoice are correct and you can see those part numbers on packaging box (see pictures above). The difference is not only "H" and "J" but also "0" and "1". I believe Mazda simply reuses the old label with wrong part number affixed to the LED headlight, but only the manufacture date is legit. Yeah it's definitely a sloppy job on this, but this's no surprise to me. Mazda can't even make fluid capacities correct in its owner's manual and factory service manual.Correction, invoice states Rev J but part is actually Rev H. Has anyone ever complained about this? Seems like a major compliance, quality, inventory control issue to be selling parts marked incorrectly on invoices.
