dashhawk speed6 profile
Flightmedic
2006 Mazdaspeed6 GT
does anyone have a profile for the speed6 I can borrow . I cant get the lcd color to look good... thanks in advance : )
i do 205/2/0
I use 255/0/0/25 for a nice bright red display for daytime use.
You can turn down the backlighting intensity at night. Hit the bottom button once, then arrow up/down until it looks right, then hit lower button again.
under what name is the boost gauge under on the dashhawk ??? Meaning what do i have to set to see my boost ???
There's two you can use. One is called Boost/Vac (which shows vacuum) and the other is Boost PSI (only shows positive values in PSI). IIRC Boost/Vac is under "Air" and Boost PSI is under "Mazda Specific"
