builthatch
guys...i'm using v24beta14
it's got mazda in the PID section, and under fuel, it has commanded a/f, a/f ratio from sensor. if i want the a/f read as a ratio report, like 14.7:1 stoich, then i'd pick 'af ratio from sensor', right? i was using "oem wide band #1 afr" previously and it seemed to work.
also, is knock the 'spark knock retard'? i guess i'll see, but i'm curious what kind of read-out it'll be and what span. i am used to an apexi power fc that had a knock meter, and 60 was the preset level for knock warning on a scale that was not clearly defined.
lastly,
what does your last tab settings page look like, on the settings editor via the PC interface, with the qtr mile parameters, hp config, etc? screen shots welcome ; )
lastly,
