Dash Speakers Quit Working
kmangione
Mazda CX-5 Grand Touring
Does anyone have an idea of how to access the connections between the dash speakers on a CX-5 Grand Touring?
Can I gain access through the glove box? Will I have to pull off the front radio panel?
They quit working while we were driving down the road. Initially all speakers stopped. Then everything except the dash speakers started working again.
Any ideas how to get the speakers working again?
Thanks!
What year? If it's under warranty, your best bet would probably be to bring it to a dealership. If it IS under warranty and you start mucking with it, you might void the warranty (in regards to whatever you muck with.)
This sounds similar to a TSB... Check this post: http://www.mazdas247.com/forum/show...-2014-Mazda6&p=6337284&viewfull=1#post6337284
Narrow it down by testing the connections using a multimeter. There is a wiring diagram for the head unit and amp. You can hit all the connections from the amp itself. Access by removing the glove box and kick panel, which shouldn't take more than 2 minutes.
