I tried to locate the two front drains in the sunroof just to make sure they weren't clogged
and cause damage to the BCM (Body Control Module) located by the driver side pillar.
There wasn't any signs of stagnant water in the sunroof tray so I assumed everything was working fine.
The only openings that I can locate in the sunroof drain are on the frontmost sides where the red straw
of my compressed air had access down a channel.
can anyone confirm this please ? and if anyone knows where the drain exits on the undercarriage,
I would greatly appreciate a picture.
thanks in advance!
from the diagram, it looks like there's a plastic drain plug/filter that may trap debris by the front wheel wells that need to be checked also
thanks in advance!
