Before we got rid of our 2013, we were getting 16mpg average, but it had a high weight to freeway.
FYI regarding ethanol-
Basic power per volume calculations and scientific study have proven that when ethanol is mixed with fuel, regardless of burn rates, the fuel has less "power" per volume. In other words, when ethanol based fuel is converted for energy (ie. burned as with internal combustion engines) it requires more. The studies performed on laboratory engines and E10 fuel causes the engines to burn through more fuel to make the same amount of energy than with non-ethanol added fuels.
In other words, the opposite effect has happened: adding 10% ethanol has the opposite desired effect. We're burning MORE fuel (in forms of less MPG for example), not less. The more efficient and "cleaner" burn was also not proven in laboratory tests, or was mathematically irrelevant. (These are from multiple lab tests I have read)
