Thanks for that video. It shows that you need to hold the parking button for 20 sec (10 sec after the first beep) to hear beep from rear and than you can set up volume for rear sensors.I found a video on another topic on this forum about the same issue:
MAZDA CONNECT - VOLUMEN SENSORES *
Hold down sensors button then press start two times, wait 10 seconds to beep and change volume of the front sensors, if you hold down 20 seconds to second be...www.youtube.com
