My 2015 CX-5, 2.0L 6M/T is using / losing nearly a quart of oil in 3000 miles. I have black deposits around each tailpipe that make it look like I'm running a diesel. My local dealer thinks this is 'within normal limits' for oil usage. I totally disagree. An independent mechanic suspects a flaw in the emissions control system (PCV valve?) that is letting vaporized oil droplets be sucked into the exhaust instead of being recirculated. The car only has 17,500 miles and is still under warranty so I want to convince the dealer to address the problem before turning to the independent. Anyone have this problem . . . or a suggested answer?
