Hi Everyone
I have a Mazda CX5 2.2 Skyactive.
The Engine light has come on and says Engine Inspection Required. A quick diagnostic check has shown error Code: P -2262 -00 - 28
I have been told that this will result in getting a new turbo. Someone else said that it is a MAP sensor problem.
I now it will need taking apart but has anyone else had this same code and issue? What did it turn out to be? When the engine light went off it did kick through the lower gears and a bit of an umph. But when the light came on it did not kick and was sluggish. When light is off it kicks OK but no response to Turbo but when light comes on terrible.
Any thoughts - is it more likely Sensor problem or Turbo issue.
Thanks for any replies.
I left it a day or 2. The lights en
When
When
