I purchased a new cx-5 here in Ireland in January. It's the platinum spec (that's the high spec in UK/IRL models) with sat-nav.  Since purchasing it, I have been plagued with excessive wind noise from the drivers door. It seems to be from the top and rear of the door window but sometimes I think it is also coming from the front of the window.
I have logged complaints with Mazda and my main dealer. They have taken the car in and tried this and that. At one stage they took the car off me for nearly two weeks and gave me a replacement car. They stuck rubber strips u inside the window seals etc to see if that made any difference. It hasn't. One thing I did notice was that the replacement CX-5 also had pretty bad wind noise from the drivers door.
The wind noise usually happens at high speed (80kph +) when there are particular cross winds. Today I went into work and heading southbound on my local motorway, the noise was crazy, like a mini tornado coming from the drivers window area. Going home on the same motorway later (heading in the opposite direction) it was nowhere near as bad. I am not talking about road noise, nor ambient rolling noise. This is wind noise and it sounds as if the door is not closed properly. The noise is intermittent and dependent on prevailing weather / wind. When it's bad, it's truly awful. I paid extra bucks for a high spec car with the Bose sound system but it's a joke with that kinda wind noise. It's as if the door isn't closed properly.
So, I am starting a thread to see if others are experiencing this. Have you tried any fixes? have you been to your dealer and what did they do to resolve the issue ?
