CX-5 ADD/HUD not recognised
CX-5 ADD/HUD doesn't work after alignment issue, have removed and replaced ROOM fuse and doesn't appear to recognise ADD. Is there a way to reset? It doesn't come up.
Settings. In Vehicle Display. Active Driving Display.
Height can be adjusted so you can’t see it but someone taller or shorter may be able to. Also check the brightness, if the guys at the shop messed with it.
Factory Default reset option at the bottom. That’s the easy stuff I could find.
Latest posts
