Custom End Links
How do these compare to AWR? I need to replace my rears, after years my AWR finally seized up.
Strength wise they are possibly stronger. The AWR use male rod ends that typically snapped right where they joined the hex body. These also don't have opposite threaded rod ends, so to adjust length you'd need to unbolt one end from the car. They should last longer than AWR because all the hardware is stainless steel.
