mazdarx7power
i'm planning to do my own fiberglass enclosure i drew a pic of it on ms paint just to get some general opinions or suggestions on changes that would be good. the mdf i was thinking of only going as high as 4 inches in height for the subs area and than make the amp rack and blend the fiberglass into the amp rack. now i've seen people use the wood rods to hold up the 12" molds for the subs.
1. would i just basically fiberglass around it with a couple layers and blend it all together with the molds or would i wrap the rods in a tube like form kinda like bazooka's and than form more fiberglass on top to form the enclosure??
2. also would i need anything special to cut plexiglass i was planning to close off the amp with it. also where the mazda sign are and the protege are going to be shaved into the mdf there and probably wrapped in that pleather material. also gonna have some blue neons under the mazda sign and protege to shine through because the amp i'm getting has a blue led on it.
3. also which way should i face the subs?? should i invert them?? which angle should i place them at angling towards the trunk or angling towards each other? subs are going to be 2 12" infinity kappa, think they'll sound good in a custom??
any suggestions and help is greatly appreciated.
