biochembruin
ddogg777 said:I think you are wrong here. The stuff we put in A/C pumps can get draw out more heat than CO2, otherwise we would be using CO2 in our A/C units!
not true. it would take too much energy to cycle CO2 from a liquid to a gas, and back. this is due to the high latent heat of vaporization associated with CO2. The A/C coolant has a lower latent heat of vaporization, but is still high enough to cool the surrounding air. Also, running the A/C pipe through the intake as a heat sink as twilightprotege was suggesting would mean the A/C condenser would have to be running, which takes power away from the engine. In any rate, you cant vent the A/C directly onto the intercooler, as you can with the DEI setup. Besides, theres no reason you couldnt run the DEI setup in conjunction with a nitrous setup. I was simply wondering if anyone had tried it on his or her car (forced induction or N/A) and what was their experience with it.
