Alright, I got a quick question. I noticed on CP-E's description of the inlet that it will fit Stock and GT series turbos. I thought the GT series had a larger inlet than stock. If it does how is this part interchangable?
so why exactly does the vacuum hose at the solenoid need to come off? Couldn't you just leave that side connected and disconnect the hose on the inlet side? Just trying to wrap my head around the problem.
with the aftermarket inlet the stock hose from silinoid to the inlet nipple isn't long enough, it's about 2 inches short, so you need to put a longer hose in there. I wastwisting and yanking and trying to get that thing off but its way down there and hard to get the right leverage. It just snapped right off on mine
the hose is not long enough, the smart thing to do is:
leave that end on the solenoid, buy a plastic/metal 2-nipple connector and connect your new hose to the end of the old hose, and connect the new hose to the inlet. wont have to kill yourself to remove the hose, and you wont risk breaking the selenoid. i suggest anyone who does it from here on out do that and save yourself a headache
