I just finished installing the pipe with my cousin too and boy was it a PITA. Shoot, I thought it was only gonna take at most an hour but we ended up working on it for 6 hours. We ran into a lot of unexpected problems. First we couldn't get the new inlet onto the turbo because a hose was blocking it from the bottom. So we took the hose out and then all of my coolant leaked out from the hose. Next, as RC08MS3 mentioned the waste gate vacuum line wasn't long enough to fit on the metal nipple so we loosened the other end to lift it and have just enough to put on the nipple. After the inlet was finally on the turbo flange, we couldn't get the hose which leaked the coolant back onto where it was supposed to go. But after all of those problems, it was smooth sailing.
Let me know if any of you guys have any dashhwak requests.
Great ... how about RPM, boost, AFR, WG%, timing advance?
Try and start WOT at the same RPM (say 3000) ... would love to see a before and after comparison.
I broke the top of the selinoid piece (not the part on the inlet but the part the line goes to), its a b**** to get it off the top of the selinoid, and I broke that little b****.
I just got a Cobb turbo inlet and haven't installed it. I wonder if I'm going to be having the same install problems you guys are having with the CP-E turbo inlet. I'm going to puchase extra hose just in case.
Does anyone know for sure if 3/16" ID is there right size to get?
How much lenght of hose should I get?
07 Silver MS3, Mazdaspeed CAI, Mazdaspeed CBE, TWM short shifter and bushings, SU Billet Aluminum Rear Engine Mount, Hotchkins RS, Cobb shifter Weight, Fuel-Filler Door, Goodridge Stainless Steel brake lines, Motul RBF600 brake fluid, Hawk pads.
Does anyone know the part number for the boost control solenoid. The nipple broke during the install. I superglued back on but not sure if that's gonna cut it.
