cp-e FMIC pics!
meth kit install with a front mount intercooler.. when mine comes in im doing it but ive only seen it done with the top mount cold pipe on here...i hate being the first one to do anything.
What's a "boost leak tester" and where can this be found?
my friend made one. All you need is a bicycle tire pump and a pvc cap. You take off the air filter on the car and screw the pvc cap on the intake pipe so no air leaks out then you pump the bicycle air pump into the cars intake and if the psi on the bicycle pump doesnt keep going up ofter pumping, you have a leak. you can usually here where the air is coming out.
