Corksport LED Fog light bulbs
Status
Not open for further replies.
Selling a used set of the Corksport LED DRL fog kit.
As seen here:
CORKSPORT LED DRL Kit
Purchased these from Corksport about 6 months ago or so and just ordered a set of DDM fog lights to change the appearance up a little bit. This kit is a direct replacement for the factory fog light bulbs and will add a nice aesthetic touch to your speed 3.
This is made to match any hid kit between the 5-6k range and really looks great when paired with an HID kit at night. I think Nataphen had some threads about these but I was not able to locate those.
The bulbs are in great condition and I even have the original packaging. The bulb type is a H11 set up so I think this will only be compatible with Gen2's.
Either way, if you are looking to upgrade your fogs with a simple swap, this is the way to do it.
I am hoping to get $35shipped for these.
Hey, I'll pick these up from you if you'll do $30 shipped to 43240. Do all the LED's still work? PM me your paypal address and I'll get you the funds. Thanks!
Shaun
What is the best way to access the fogs for installation of these bulbs?
RichB,
When I had yellow bulbs in mine, I pulled the uncarriage cover off (pretty easy, a handful of 10MM bolts) and access the foglights from underneathe. It's fairly easy to do.
Ok, I have taken my bumper off a few times and was hoping I didn't have to do it again to change fog light bulbs.
Thanks!
Status
