For the front SPC sells them. The problem is, that nobody makes one for the rear.
Thank tibimakai. Is there any point in just getting them from the front?... or is it weird to have a perfectly aligned front, and then -2.0 rear?
The ones you see listed for the front (from various manufacturers) are generic kits made in different sizes that work on other strut-type front suspensions including many Mazdas. Sized correctly, one of them will "probably" work on the CX-5, but no guarantees.I don't understand, why they even make them for the front and not for the rear?
The SPC 16mm camber bolts replace one of the 2 bolts (I can't remember which one) in picture 2D on page 1 of 4 in Corksport's instructions. The 16mm size refers to the bolt shank, not the head or the accompanying nut which Corksport calls out as 21 and 24mm respectively.Checked out the SPC bolts. Says they are 16mm? is this correct? I've read over the cork sport instructions for installing the springs and there is no 16mm bolt
So could this be done in the rear too?
Unfortunately no. While the front is a McPherson strut setup, the rear suspension is and upper/lower control arm set up with a separate spring and shock. It is the coveted adjustable upper control arm that everyone seeks for camber adjustment.
Camber arms, can't accept camber bolts?
$360?!? wow
and wait full outward adjustment -.1 ?
