Street performance coilovers for the 4th generation 2019 and newer Mazda 3
corksport.com
A brand new coilover design from CS drastically improves the handling of your 3 with 5K front and 7K rear springs, coupled with 30-way damping adjustments.
We carefully calibrated the coilovers to produce a sporty ride that is just right for street use but can be adjusted to give great driver feedback for autocross or track day use.
https://corksport.com/new-products/
In the front, you can go from ~0.5” taller than OEM all the way down to ~2.25” lower than OEM (+0.5” to -2.25”). For the rear, you can go from ~0.75” lower than OEM all the way down to ~2.25” lower than OEM (-0.75” to -2.25”).
This is 2.75” of total adjustability in the front and 1.5” of total adjustability in the rear.
We have the option to upgrade to Swift Springs -𝗬𝗲𝗮𝗵, 𝘆𝗼𝘂 𝗿𝗲𝗮𝗱 𝘁𝗵𝗮𝘁 𝗿𝗶𝗴𝗵𝘁!
For those looking for more subtle heights for that OEM+ look, the max height is ~0.5” taller than OEM in the front, and ~0.75” lower than OEM in the rear.
For those interested - we are in process of releasing NEW Coilovers for the 1st and 2nd Gen Speed/Mazda3 and the 3rd Gen Mazda 3 later this year, and maybe the CX30!
