Cooling issue
TheCV
2002 Mazda Protege 5
So here's the issue. The car will idle all day long and not overheat, as soon as you drive 1/2 a mile it starts to overheat and bubble back into the reservoir. I have removed the thermostat and it still overheats, the return hose is hot the intake hose is cool. I have checked and the water flows freely through the radiator but is not flowing back out the return hose. Any one have any ideas before I replace the water pump?
running A/C driving? both fans OK?
Did this come on gradually or suddenly?
If you're at or over 100k, change water pump and belt. Tune up can't hurt either while your at it
