heitktebinltraj
- Protg5
This morning I noticed a small puddle of coolant near under the passenger side of my engine block, about the size of a loaf of bread after my car had been sitting all night. I drove it to somewhere in the neighborhood, probably 5 minutes total, and when I parked it immediately peed out the same amount of coolant as before and then stopped. I waited for it to cool down and shoved myself underneath to see if I could find the source. Tracing it up from the ground it went to the ground off my skid plate, to the skid plate from what I think is the water pump, to the water pump from where the lower coolant hose goes into some metal tubing that branches off, located underneath the heat shield.
So my questions are: is there anywhere further up that could be the source of the leak? What exactly is this metal tubing and is it a likely leak culprit?
