converting engine to run on cng
Rickt
2014 Mazda CX5
I read an article on this. Has anyone done this or have any thoughts on the subject?
Default Mazda Announces Mazda3 Skyactiv-CNG Concept for Tokyo Motor Show
not sure if this was posted yet or not
its worth mentioning that the current Skyactiv 2.2 engine has a 14 to 1 compression ratio, that should be excellent for Natural Gas
Mazda will blow the wraps off the new Mazda3 Skyactiv-CNG Concept at the 2013 Tokyo Motor Show next month, alongside the already released Skyactiv gasoline, diesel and hybrid models (the latter only available in Japan).
As the name suggests, the Mazda3 Skyactiv-CNG Concept runs on compressed natural gas (CNG). The prototype features a dual fuel system than runs on both gasoline and CNG. Mazda says its Skyactiv-G gasoline engine needs minor modifications to run on CNG as well, since it burns fuel at a high pressure and it has a high compression ration, just like a CNG engine.
According to the company, the Mazda3 Skyactiv-CNG responds to market trends and that vehicles with CNG engines reduce emissions by about 20 percent compared to those with gasoline engines of the same displacement. The Japanese carmaker didnt say whether the study will spawn a production model but that is likely to happen, since in European markets like Germany and Italy CNG vehicles are popular.
Skyactiv-CNG study aside, the Mazda booth will also include Skyactiv-Hybrid models, which are on sale only in Japan, where the Mazda3 is called Axela. The hybrid pairs an electric motor with a 2.0-liter Skyactiv-G gasoline engine.
Mazda will also present in Tokyo the Atenza (Mazda6) ASV-5, which is equipped with next generation safety systems. One of these systems enables automobiles with an in-car autonomous sensor to communicate with streetcars, helping to prevent collisions and make traffic smoother and safer.
http://www.carscoops.com/2013/10/maz...activ-cng.html
Interesting concept.
One big question is where the CNG tank will be installed (maybe will be 6 gallons or so), it's bulky, weighs nearly 100 pounds and most likely won't be mounted under vehicle.
CNG conversions have to be EPA and DOT approved, and are VERY expensive. Just take a look at what it costs to convert an F-150.
Yes, but this Mazda if was to go into production would not be a conversion (such as the F-150 example), although at this stage just a "concept". It would be more along the lines of the Honda CNG Civic (previously known as GX, I have one) currently in production.
