Constant Alternator Belt Breaking
shawn46
02 Mazda Protege ES, 01 Mazda Protege LX, 2004 Mazda RX-8.
My Protege has taken a liking to throwing alternator belts, and i can't figure out why! the belt sequels when i put an electrical load on it, such as turning on the headlights, fan ect, and I blow the alternator belt when i drive after dark.
I have changed the alternator twice now, as well as the water pump and all the pullies
i also live in Canada, so it's cold, if that makes a difference
Sorry about the repeat post, i searched around a couple forums first, but i haven't found an answer that works
2001 Mazda Protege
1.6L Manuel
Te Belts on my daughters P-5 were howling and I thought it was the compressor. Mechanic changer alternator, bearings seized. Threw another Alt belt 3 months later. Went threw the forums and tried the 2 new gator back belts $$Big money but no more squeeks!! Go Me:)
My 1995 Protege threw an alternator belt when I let someone borrow it. Thankfully they didn't keep driving. I installed a new one, but it howled like a banshee at start for about a minute, and sometimes when it was under load. This lasted several months until I finally got off of my ass and tightened it. For my year you just need to loosen the two bolts (12mm socket I think) near the alternator (they faced opposite directions on mine) and then turn the belt tightening bolt clockwise to tighten, and then finally tighten the two alternator bolts to secure everything. Yeah, crappy instructions, but any Haynes manual will show how. I didn't have a method to measure the tension so I just guessed.
