I will have both IM and TB gaskets... I'll double check the fit on the TB's on my mani's as that has not been done just yet... the coolant bypass part of things we'll also have worked out, but doesn't require a fitting from what I have worked out right now.... but I will provide caps for the open nipples... so that should cover you guys. Final pricing... 72 for a set or 48 for an IM by itself, or 25 for the TB by itself. The test car did not need any additional gaskets or the like, so we will stick with that format, and you will just simply have to pull the IM back, slip the spacer onto the studs and close things up!
Have a good one,
Steve
