Can I interest you in a Msp Turbo setup for cheap?
If I had fewer miles yes! I need to keep this thing reliable for now
I'm right there with you my man...even after my header swap-in + new gaskets, I'm faced with more exhaust leaks and potentially a motor mount failure. Booyyy I'm done spending money!!Update to the check engine light:
I found my scanner (after searching everywhere) and got a P0300 and P0660 code.
Already ordered the solenoid (which won't be here until 8/28 but I only paid $10 vs. 150)
I was surprised to find a Mitsubishi logo on thembut if it works it works. Going to try to find the vacuum leak at work next week and inspect the plugs and wires in a moment. if it ain't one thing its another![]()
That's why I asked. I broke off a bolt on my GF's Sonata oil pan and don't want to deal with it.
Our oil drain plug is bad too,... It's got a huge head on it, I think it's 19 or 21 mm but has really fine thread with very little torque,... Then you put the huge wrench on it and strip the threads.
My friends truck is better,.. Same big drain plug but a 10 mm head on it.
Check spark plugs, leads and coils.
