??cobb sri??
ok quick question i got a cobb sri needs to be cleaned can i use the k&n filter clean kit or do i half do get the cobb filter kit?
You can also just use car soap or even plain old dish soap to clean the thing, rinse it well and let it air dry before re-oiling.
Filter "recharge kits" are a great cash cow for the companies that make them, all you really need is the right light oil.
Oh yea, cuz you dont wanna jack up your MAF sensor. That would kinda suck. Ehhh.. just a get a recharge kit. Cobb or K&N
You won't do any permanent harm to the MAF, no matter what oil you use. A shot of brake clean fixes it right up...though you want to let it dry thoroughly first...phosgene gas ain't fun.
Get a dryflow, that's the real answer.
i have the cobb and k&n recharge kits. i prefer the k&n bscause the oil is "pressurized". i get a more even "coat". the cobb oil cap squirter sucks, last time i used it i overoiled so bad it dripped all the way to the pavement. -note k&n oil is red, cobb mesh is blue...filter ends up looking ~purple
dont use that maf is too sensative. just get CRC maf cleaner!6.99$ @ autozone...sensor safe it is
You can't read man. I said that you can OIL THE FILTER with whatever you like, technically, and a shot of brake clean will remove any residue from the MAF. I also said getting the right filter oil is important, if you insist on using an oiled filter in a MAF car, which I wouldn't.
I've used K&N oiled cotton gauze filters over many years in many different vehicles with good results and no problems. They have a high CFM flow rate and do well even when very dirty.
You shouldn't clean them very often, though. Biggest mistake people make is that - cleaning too frequently and reapplying too much oil. Once every 50,000 miles is about all you need unless you are off-roading in high dust situations.
I currently run K&N's on three vehicles, an Aircharger cone on my Armada, a drop-in on my wife's Volvo, and a circular style K&N sits on top of the Weber carb on my CJ-5 Jeep. No problems with any of them.
And on all those present and former vehicles, I've never had oil get to the MAF sensor, probably because I don't clean frequently, and don't over oil. But it's easy to safely clean a MAF sensor, whatever the reason you might need to do so.
Having said all of that, I do think that the AEM Dry Flow filter, or filters of that type, are a better solution, now that we have that option. I think it will do a little bit better job in filtering out the very fine, small micron particles, although there is not much evidence that particles that small actually cause any harm.
you cant read sir i said brake cleaner will destroy the maf use the 6.99 maf cleaner. go read up on how sensitive the MAF SENSOR really is before you suggest a way to destroy it to a fellow member(upyours)
