S skrappyyy Member : Mazda Mazdaspeed3 Jul 12, 2009 #1 After installing the cobb springs, I hear one of the sides creak while i go on a driveway at an angle, any thoughts as to what this could be?
R RichB Member : 2007 Cosmic Blue Mazdaspeed 3 GT Jul 12, 2009 #2 Might be a loose bolt somewhere or you need to put grease or something over there.
S SallySpeed3 Member : GT Mazdaspeed3, Cosmic Blue Jul 12, 2009 #3 How long have they been on your car? I hear it takes at least a week for them to fully settle.
R RichB Member : 2007 Cosmic Blue Mazdaspeed 3 GT Jul 12, 2009 #4 It shouldn't be making noise while they settle.
P PaPaSpeed Member : Mazdaspeed3 Jul 12, 2009 #5 Check the torque on the sway bar end links. That's what was causing my creak. Try to crawl under there under load with your 17mm and 14 mm, and tighten them down. Also check the top nuts on the bar and grease the fittings. Thats my guess.
S skrappyyy Member : Mazda Mazdaspeed3 Jul 12, 2009 #6 Thanks, I'm pretty sure its the sway bar end links now that you mention it!
S skrappyyy Member : Mazda Mazdaspeed3 Jul 16, 2009 #8 dizzin9 said: pics? Click to expand... will do when i get ahold of a camera!
S skrappyyy Member : Mazda Mazdaspeed3 Jul 19, 2009 #11 17x8 245/45/17 up front and 17x8 235/45/17 down back rolled rear fenders
