Cobb springs installed
skrappyyy
Mazda Mazdaspeed3
After installing the cobb springs, I hear one of the sides creak while i go on a driveway at an angle, any thoughts as to what this could be?
Might be a loose bolt somewhere or you need to put grease or something over there.
How long have they been on your car? I hear it takes at least a week for them to fully settle.
Check the torque on the sway bar end links. That's what was causing my creak. Try to crawl under there under load with your 17mm and 14 mm, and tighten them down. Also check the top nuts on the bar and grease the fittings.
Thats my guess.
Before
After
