I'm having clucth prblems on a 2002 B2300 Mazda Truck with 11,300 miles.
The first time i had a problem was when the clutch and the brake peadle fell off while drive and i was bringing it to the shop because the Emergency cable was broke Luckly i was only going 35 miles a hour and just threw the truck into the median past the alexs in mudd because i had no brakes and no clutch to down shift and the truck then was only 13 days old and had only 650 miles on it. Since then i have the brakes all around replaced twice and the rear end replaced and the leaf springs reaplaced and the fule pump replace and so on the list keeps going and going. Any ways the clutch they all ready replaced the throw out bering once and realined the clutch 6 times and i'm still getting a growing noise and schreing noise when i press the clutch in there is a service bulletin out for is at "http://www.alldata.com/TBS/34/02346484.html" the tbs number is "0500402" but now they won't fix the problem i having problems disguaging the clutch when it makes the noise and i'm having no luck getting this resloved and they are saying it is normally for it to do that but i have never had a truck that did it
even are 1972 VW bug has no noise with the clutch why is this one haveing so many problems. And is it the clutch or the tran. because it is comming from inside the bell housing because i took the inpection plate to see if the noice is comming from and thats where it is comming from. Help please.
