Clutch problem - sticking... help please!
fun.
06 Mazda 6
I have a 2006 Mazda 6 with 104k on it. The clutch started sticking a couple weeks ago right where it would engage into gear, and I'd have to use my foot to pop it back up. It only happened here and there until finally, it stuck to the floor and became very difficult, if not impossible, to get out of gear. So everywhere I looked, it seemed that the slave cylinder was the culprit. I got a new one at AutoZone, replaced it yesterday, and the car ran great last night and this morning.
Then, this afternoon, in one 10 mile trip, it went back to the original problem. Stuck with every gear change, then stuck to the floor after I pushed it in and darn near wouldn't come out of gear. What in the world could be the problem?
Thanks!
Crawl up under neath it check all the connections, theyre should be one that lead somewhere from firewall down to the tranmission to engage the clutch, check for tention on the line, check the lev on the machinal spring device the cable goes on, if everything checks out normal it maybe internal, or the pedal assembly is bad in which idk never seen it but who know..?
Sounds like clutch slave cylinder needs replacing as I suspect is drawing in air or leaking fluid just pull rubber back and see if wet
