TX Speed Demon
PM JDM Sam / Crossover Auto about the excedy clutch. He had the prototype made for the MSP version and could probably cut you a good deal. Tell him I sent you.
chuyler1 said:I honestly never looked into the how but almost every person I talk to that drives standard says not to idle with your foot on the clutch.
I just did a quick search and came up with this...
1. Q: When waiting for a traffic light to change should I have the transmission in neutral or in 1st gear ready to go?
A: Neutral. If youre rear-ended or your overtired leg involuntarily releases the clutch pedal, it will be impossible for the transmission to accidentally engage and unexpectedly propel you forward. Also, when youre in neutral, you dont have to keep your left foot on the clutch pedal-your leg wont get as tired and youll reduce wear and tear to the release bearing.
Remain alert while waiting, especially watching the rearview mirrors and the cross traffic lights, and you should have ample time to prepare yourself to move.
luckyP5 said:not trying to insult your intelligence. but are you sure it was slipping? i live in Ottawa too and it was an icy day. perhaps tire slippage?
paranoidxe said:15,000km really isn't enough for you guys to be the main factors of why the clutch went out, maybe the owner before you wasn't a very good caretaker of the car. My car is at 80,000 miles and it seems to be doing just fine.
The main things (other than just using it) that would cause premature wear on the clutch:
- is launching the vehicle too high, I don't ever launch the vehicle from a stop from higher than around 1,500-1,750RPMs
- pressing the throttle inbetween swifts too early, to a point where the clutch is partly engaged and the driver is giving it gas.
- "riding the clutch", in which the dead pedal never gets used, your foot is always on the clutch pedal.
- using the clutch everytime you need to pull the shifter out of gear, you can pull the shifter out of gear without use of the clutch and it won't hurt the car.
Otherwise, I'd say most to blame is the previous owner. I think its pretty unlikely to burn out a clutch within 15,000kms..in my Talon the clutch is going on 10,000 miles and its my racer so it gets abused..on top of this the clutch is bone stock and it hasn't started slipping yet.
aMaff said:Really? How?
ohfosho said:well pulling the gearshift out of a gear without the clutch being pushed can hurt your syncro's...it wont hurt your clutch, cause that has nothing to do with your clutch...thats in your tranny. burned out syncro's suck though...
with regard to holding the clutch in during red lights...i can see it eventualy weakening the presure plate. figure the pressure plate fingers are out of thier natural state for so long, and being held at the unnatural state for so long could reduce thier pressure onto the clutch disc after a while...but i dont think that that is a major killer of clutches...many people do it, and it has been done for years.
a lot of people like to think that they are downshifting when they are coming to a stop light...meanwhile they have the clutch all the way in the whole time, and are putting the gear shift in each progressing downshift...therefore never actually engaging the gear...and its just wasting the syncros...
skinnyjoint said:pushing the clutch in to take out the shifter out of gear does not effect the clutch... and pulling it out of gear without properly matching road speed can tear up synchros... i would agree with everything else u said but this fact is wrong
Topher said:$800?
damn, i paid a mechanic on the side $100 to install my clutch/flywheel...i still have my stockie for sale![]()
tiwing said:If I ever hear "We won't install customer parts", I'll be out the door so damned fast. Both STEALERSHIPS I go to have no issue with non OE parts. they even source parts for me if I want them to. And you'd expect the dealerships to say no first. Go somewhere else, and get a new quote!!
Topher said:$800?
