jrodhotrod
Contributor
- 2003 Mazda Protege5 (Mine) 2002 Nissan Sentra GXE (Wife's)
flat_black said:t3ase: Your problem can probably be solved by adjusting the pin on the back of the clutch pedal, so you don't have to floor it as hard. It's two nuts, 12mm, one to lock the pin in place, the other to adjust the distance. If you want, I can send you the section from the FSM where it specifies how to adjust the clutch. Just ask. =)
I wouldn't mind getting this information. pm me. Thanks!
