cluster swap and PD/PW 2003 DX
Toyojake
2010 Mazda 3- 5 speed
Howdy, my buddy and I are fixing up a 2003 protege, and in the process wanted to add power locks and windows., and a cluster with a tach. Planning to get everything from the yard. My question is about the cluster, I've read from research that the cluster needs to have no keyless entry to work in the DX, other than that it's plug and play, how can I tell if the donor car at the yard has keyless or not? That and any advice or extra parts needed to do either the locks, windows, or cluster would be greatly appreciated.
Thanks guys
well, basically you can make it work either way. You can run a jumper wire to the cluster from the purple/white wire of the diagnostic port in the engine bay. Just run it through the firewall.
