wolverine_man
- 2008 Mazda3 S GT Sedan
I just started to notice a faint clicking - maybe chattering - noise coming from the front of my car - mostly right side but sometimes driver side as well. I only hear it once I get going down the road and it doesn't seem dependent on whether I am turning or whether I am going over bumps. I hear it best when I am not on the freeway but going at a decent speed down a major road.
It sounds pretty close to the clicking sound my glove box is making (which I need to fix) and I was actually convinced that the sound went mostly away when I opened the glove box door. It is also very cold out right now in Michigan, but I am worried that it is related to the install I did last week on my Eibach Pro-Kit. I have put about 250 miles on my 3 since that install. I also have 18k total miles on my 3.
Also, as I posted in a different thread, I placed the clear rubber tubing on the Eibach springs about in the middle of the spring on install, as I was told that tubing doesn't do much. Perhaps I should have placed that tubing at the end of coil where it makes contact with the strut assembly? Would that mistake cause the noise? I just can't believe that tubing would last long and not get worn out like that, though. Seems like the rubbing would wear right through it.
Is this the culprit (note, this is not a Mazda3 kit, but just to illustrate the tubing):
Where should that tubing have been placed on install? Mine was slid somewhere around the center of the coils.
