Just turn ur wheel to the side and go from the wheel well. I think i had to take out like 2 or 3 screws and stuck my hand in there to get it out.
There is a clip that you push on the side closest to you (ull feel it) and just it'll pop out. Then unclip the wire from it, clean it with a microfiber, and spray it with a light coat(let it dry), then more coats (let dry), and ur final coat.
I blacked mine out really dark but when you start make sure you dont spray on a lot. Just couple of run throughs to start it off. (you dont want to put too much cuz it might drip) Make sure to even it out. Then put the wires back in and just push it in(it should clip) and ur good.
Hope that gave you a brief idea.
It turned out to look really good and like i said i will take pictures when i get home soon and take some at night to show you how they look.
Im going to be doing my rear reflectors maybe today so ill do a how to on side markers and rear reflecors. (not like it's hard to do)
