Clean Motor?
I was just thinking of cleaning my bay as well. there's a bunch of different products...
I know of a place that steam cleans engine bays... This is NOT a pressure washer type thing.
Please don't use simple green to clean the engine in your. It works well, a little too well, simple green is not good use on aluminum, and seeing as there is a large amount of aluminum in our engine compartment, it might not be a good idea to use it.
y? most shops use simple green degreaser when cleaning motors or steam clean them.. its metal...its ok.its not going to eat through the block..
I've read a lot about people using Simple Green, but the product even warns not to let it sit on aluminum for long. Most people spray it on (I'm sure a diluted 3:1 solution would work well, and be potentially less damaging), leave it for maybe 5 mins, and then gently spray off - no power washers. Just use the hose with no nozzle, or if you have a gentle setting on the nozzle for watering plants. I haven't done mine yet, but I will when it gets a little nicer out.
I also read that Extreme Simple Green is better suited and less damaging to plastics and rubbers than the standard stuff: Extreme Simple Green
i use a simple green dipped rag, and a wet undipped rag. it dont get less complicated than that. i dont touch the intercooler (shroud only), or block. the gunk in and around there is what prevents your car from blowing up.
its a mechanic's secret law, that if you want to keep your car running forever, dont clean the grease around the actual block, or head, because its really what keeps the engine together.
