chuyler1 said:When you pull off the panel you will realize that your options are limited for placement. The prime spot right above the gauge bezel is where one of the pins is located. And less than a 1/4" from that is a stiffening bar that goes the rest of the way up the pillar.
After looking at the photos of your tweeters in your thread, they don't look much bigger than mine...but DLS's website says the mounting depth is only 1.01" for the Iridium tweeter.
There isn't much additional room back there, certainly not another 1/2". However, if you are carefull with warming the panel, you can probably get it to pop out enough to install your tweeter.
	chuyler1 said:Haven't commented on sound yet because there is still a missing link...the mids. Plus I haven't actually wired up the tweeters. It was too dark last night to pull the wires through the dash. Right now I'm running the midbass drivers full-range so I at least have some sound. They've got some kick to them. The stiffer cone (compared to the eclipses) makes a huge difference in the low end...so much that I need to pull apart the doors and add more sound deadening material.
I'm sure you could get a new set of a-pillars at a junk yard for a few bucks.
chuyler1 said:I used a hole saw to cut the hole. The mounting diameter was 45mm and I used a 1.75" bit and it worked out fine.
chuyler1 said:A little over an inch I think.
