check engine light
with an OBD II module
read the code
than note it for a future inspection
and finally push the little button RESET (band2) (hold it 2-3 sec.)
drive the car for two days and it will automatically reset itself thats what i did
david_shea said:
take off your negative battery terminal for at least 5 mins., that should clear the code.
I would suggest getting the code read at Autozone or one of the similar auto parts stores first.
However, if you know what it is and just want to erase it, you can disconnect your negative battery terminal too. Once you do that just press on the brake pedal a few times and your brake lights will turn on, draining the leftover power in the system. Once your brake lights don't turn on anymore, then reconnect the battery cable and your ecu and cel will be reset.
i know what the code was ...it was a multiple miss fire.....caused by bad plug wires....
thanks all for the replies
