Check engine light please helppp*******
P1288 -cylinder head temp sensor out of range
The U2064 is basically telling you got the problem above.
This is from googling but it seems all P1288 is related to the same thing, in different cars. Gotta replace that sensor i guess.
go to autozone. if u already did, dont they tell u what it is and how to fix it? sry not much help
P2251 is for the Front O2 Sensor, open current (usually means its bad)
U2064 is just an error from the ECU because there are multiple CELs at once and it can't send them all.
U2064 Is a code you get from an AP every time you get ANY CEL. It is AP specific as I have never seen that code with my DH but I get it every time with the AP. I get the common Cat Warmup CEL pretty often.
CEL came on with code PCM P2251 twice and each time I cleared with the AP and since the 2nd clear it hasn't come on. Is this cause for concern ???
