Check Engine code says Catalic Converter bad!
should work for u. you have a header, its just stock
oh I see. Ok, cool man! Thanks for that link. I might though just get a cat sooner, just so I don't compromise power and mpg.
How cheap is it to get a straight pipe? Can a muffler shop weld one in, removing the cat in Calli, or is it illegal for them to do that?
Well I do know that around here a muffler/body shop will not work on your car if you do not have a cat nor will they remove it unless its being replaced. I think Cali prohibits the modification of the stock exhaust period
I did the non fouler trick on mine and i have stock exhaust. Really easy to do and I havent had my CEL come on and i've been driving it about 9 months now
My cat is bad. I had a random multiple cylinder misfire for awhile and i heard it clogged up my cat with all my unburnt fuel. And I had to get it to pass emissions and as all of you probably know you cant pass with a CEL, at least here in utah...
So you passed your smog using the non-fouler trick even with a bad cat?
Yeah I passed. All i have is safety and emissions i have to do, isnt it only cali that does smog? all they did was plug in the OBDII reader and my car told it that it was good to go
