Speedy3 said:Found another one. Before turning on the ignition, hold down the DSC button. Turn on the ignition, wait a couple of seconds then let off the DSC button. Both the DSC Off and the Traction Control indicators stay lit until you press the DSC button again. I tried driving withe both lit and noticed traction control and DSC are disabled. The first one I posted (holding DSC for 10 seconds) doesn't disable DSC or Traction control, but doesn't allow you to toggle DSC anymore.
When I get a chance (and when the roads are dry), I will try both while logging Boost Pressure in 1st and 2nd gear.
Here's a list of notable qwerks:
1. With Ignition on, hold DSC for 10 seconds. DSC Light goes back off and stays off for the duration of ignition cycle. Cannot toggle DSC anymore.
2. With Ignition off, hold down the DSC button. Turn on the ignition, wait a couple of seconds then let off the DSC button. Both the DSC Off and the Traction Control indicators stay lit until you press the DSC button again.
(rei)
Bring on Contra.
in the 99+ mustangs there is a pretty complicated series of button presses to disable the seatbelt warning tone.
You can get 100% boost in 1st and 2nd. Put the key in the ignition, hold the DSC button down, start the car, wait 2 seconds, then let go of the DSC button. This will disable the boost cut in 1/2, stability control, and traction control.
Apparently we have an answer:
I'm too tired to try it tonight. Anyone game?
Hmm, guess I heard wrong. This does completely disable both DSC and TCS systems. Apparently you can't disable the 1/2 boost cut. Sad panda.
